Latest post 07-01-2007 3:52 PM by jk1002. 3 replies.
Page 1 of 1 (4 items)
  • 07-01-2007 11:08 AM
    • Top 75 Contributor
    • Joined on 04-01-2007
    • UK
    • Posts 970
    Beo5 Frontrow Mac controller?
    Will the Beo 5 be able to replace the Apple remote in controlling Frontrow on Mac or am I just wishful thinking that it can control 3rd party devices via software updates?
  • 07-01-2007 1:03 PM In reply to
    Re: Beo5 Frontrow Mac controller?
    It seems that most products bite their teeth out with the fast scrolling. Beoport can't, Beosystem can't, IRED/Lintronik can only workaround. It seems to be very unique to Apple how they implemented that, I would not expect Beo 5 to be able to handle that.
    Without fast scrolling there is not much of a point in my opinion.
  • 07-01-2007 2:55 PM In reply to
    Salling Clicker does fast scrolls on Macs. Wish there was a way to control B&O equipment with the Clicker! Big Smile
  • 07-01-2007 3:52 PM In reply to
    The salling clicker actually provides an object that you can call from Apple Script. I used that initially to implement my fast scrolling workaround IRED/IRTRANS. Holding the cross down started it, pushing any other key stopped it. That worked amazingly well. However when I upgraded my Imac to 1GB of RAM the scrolling became to fast and you couldn't read the text anymore. So I switched back to some sort of "Page Down" "Page Up" model which is OK too.
    I believe that Kjeld implemented fasts crolling with the USB version of lintronik, so there are ways to get this done.
    JK
