Latest post 04-01-2010 10:07 AM by burantek. 5 replies.
Page 1 of 1 (6 items)
  • 04-01-2010 7:50 AM
    • Noah
    • Top 500 Contributor
    • Joined on 12-16-2008
    • Switzerland
    • Posts 120
    • Silver Member
    Need help connecting a pair of Beolab 4500 to a Beomaster 2400-2
    Hi everybody
    Can anyone give me a advice how to connect Beolab 4500 speakers to a vintage Beomaster 2400-2 amplifier? Is that possible anyway??
    Thank you for your help.
    Noah
  • 04-01-2010 8:52 AM In reply to
    Re: Need help connecting a pair of Beolab 4500 to a Beomaster 2400-2
    Yes, I think you need speakerlink cables available from B&O dealers or www.soundsheavenly.co.uk
    Regards Graham
  • 04-01-2010 9:13 AM In reply to
    Frankly, I'd try using standard 2 pin din from the 2400 into the 4 pin din socket on the 4500's.
    The 2400 won't accept the 4 pin Speakerlink plugs... The 4500 will accept 2 pin plugs.
    You won't have any display... but I am not certain the 2400 would even push display data in the first place???
    I am also not certain about any triggering that may be required... I suppose you could disconnect the amp in the 4500's.
    If it were me: I'd look for a BM4500... That way you would have the full boat... a well matched system w/ full display via Speakerlink. Then get an old set of single fret passives (S45) for the 2400, or sell it off to fund the BM4500.
    • B&o bottle opener
  • 04-01-2010 9:37 AM In reply to
    burantek:
    No. Although I guess it can be done as you suggested, IMHO using these speakers with this Beomaster is a waste of both devices.
    -mika
  • 04-01-2010 10:04 AM In reply to
    tournedos:
    burantek:
    Pointless. What is the 2400 doing in this setup exactly? We had a question a couple of months ago about using Beolab Pentas with a Beomaster 8000....why oh why oh why? If the amp is in the speakers, and the Beomaster you are using has a better internal amp, then don't bother :P
  • 04-01-2010 10:07 AM In reply to
    j0hnbarker:
    tournedos:
    burantek:
    I agree on both counts.
    I would go for the BM4500 and do it right. The speakers in question are too brilliant to handicap. And there are few things sweeter than a 2400/S45 combo if you decide to keep the 2400.
    • B&o bottle opener
