1st March February 2012
Latest post 03-26-2010 6:03 AM by Dave. 10 replies.
03-22-2010 10:30 PM
sodoi18
- Joined on 02-06-2010
- USA
- Posts 194
What is wrong with this Beolab 4000 and Beocenter 2500 setup?
I am unable to get the shining surface on the inside towards the beocenter 2500 with the "power" light on bottom side - see picture 1.
It may not be obvious, but most of the setup pictures I have seen any where have the shiny surface inside and the speaker the grill side outside. The problem is simple to solve by rotating one speaker vertically but that will place the "power" button on the top for one and bottom for the other - see the picture 2 in the response. I did not know how to upload more than one pic
It's strange but I cannot duplicate the setup as shown on the B&O website. I am confused and need help!!
Beovox RL 60.2, RL 6000, S45-2, CX 50, Cona, Beolink Passive, MCL2P, BM4500, Beosound 1, Beocenter 2500, Beolab 2500, Besound 4000, Beolab 4000, Beocom 6000, A8, Beosystem 1
sodoi18
- USA
- Posts 194
Re: What is wrong with this setup?
second picture
sodoi18
- USA
- Posts 194
Re: What is wrong with this Beolab 4000 and Beocenter 2500 setup?
I guess I want to setup like this with the "green/red" power lights on bottom and the shiny side towards the system.
Russ
- Joined on 05-07-2007
- Washington, DC USA
- Posts 641
Did you purchase the speakers new, or used? Check the serial numbers (under the speaker grille), they should match and have an L and an R on the 2 speakers. I suspect that you have a mis-matched pair.
We kid because we love.
Bang & Olufsen Tysons Galleria
McLean, VA USA
Jonathan
- Joined on 05-03-2007
- Melbourne, Australia
- Posts 1,164
odd... seems either you have two of the same speaker (ie 2 lefts or 2 rights) or B&O use two of the same speaker in their photoshoots. I don't have lab 4000s anymore, but I suspect you have 2 unmatched speakers. What do the serial numbers tell you? are they different? (I know on my lab 8000s the matching pair have the same serial numbers)
My B&O: 2009 Catalogue and Pricelist
sodoi18
- USA
- Posts 194
Looks like I am going back to my orginal setup - see picture
Thought I could upgrade to Beolab 4000..but made a mistake on ebay...did not pay attention. You guys are right..both of these are R speakers....Should not be a problem If I want to hang them on wall some where...does it matter in terms of output?
I also noticed that these speakers have the L and R button at the back to take care of this..is it correct.
If any one interested in getting them from me...let me know
Jonathan
- Posts 1,164
I'm interested...
I sent you a message
Dave
- Joined on 04-17-2007
- Brisbane, Australia
- Posts 2,328
jldmelb:
I'm interested...
But he's in the US mate, so you'd also have to change the power supplies. :(
Might as well keep them if you can get used to having one of them upside down, or as you say, hang them on the wall. Because of their L and R switches output will be normal. Did you get them cheap?
sodoi18
- USA
- Posts 194
Made a mistake and I don't think I got cheap either. Again, its a relative question: what's cheap?
Dave
- Posts 2,328
sodoi18:
I think if you paid more than $1000 USD, then you were jipped (otherwise anything below $1000 USD is reasonable in my opinion), and you should chase up the seller on this matter... that's if the listing was inaccurate, though you weren't to know, were you! Did the seller state that he was selling 2x right hand units?
Page 1 of 1 (11 items)
