Latest post 03-20-2010 11:31 AM by ds64442. 8 replies.
Page 1 of 1 (9 items)
  • 03-06-2010 11:11 AM
    Beomaster 5000 problem
    Hello!
    I'm new to this forum and B&O products in general, i recently bought beomaster 5000 and RL60 together on ebay for a cheap price. But when buying it, no cables/connections or manual came with it. Now i got all cable and connections for aux and turntable, but i can't get the beomaster to work, whenever i plug it in there's a tiny dot on the screen, and when i press "store" it starts blinking "P". I have been searching a lot on the internet on how to make it work, also a lot on this site, but i cant find any solutions. help!
    Jostein
  • 03-06-2010 12:05 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beomaster 5000 problem
    The tiny dot is the standby indicator.
    To switch the Beomaster ON, you need to select a source like f.e. FM, Tape or Phono.
    STORE is for storing preset stations once tuned in.
  • 03-06-2010 12:18 PM In reply to
    Thanks for letting me know it is the standby indicator, as you can tell i have no knowledge of how it works. although when i do press phono, while having my turntable connected and running, nothing happens.
  • 03-06-2010 12:34 PM In reply to
    try turning the volume down
    look for the [v] key
    if the beomaster shows 00 then you know to turn the volume up
    should not need more than say 35 as a volume level - certainly do not go to the max of 72
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 03-06-2010 12:37 PM In reply to
    Well when i press on for example phono.. nothing happens, the dot is still there and nothing else.
  • 03-06-2010 12:41 PM In reply to
    that is not so good
    you should see PH
    try pressing [TAPE] to see if you get TP
    pressing [P1] should get P1
    even without the aerial see if you can hear static
  • 03-06-2010 12:46 PM In reply to
    no, can't see anything on the screen, i cant hear any static either, except when disconnecting/connecting power
  • 03-06-2010 3:19 PM In reply to
    • Dillen
    • Posts 5,008
    It's very common to see the front panel of the BM5000 completely disabled by a broken ribbon cable
    inside the Beomaster.
    I suggest you try using a remote, that'll be a Terminal 5000 or a Master Control Panel 5000
    if you have one of them.
  • 03-20-2010 11:31 AM In reply to
    Hi according 2 manual press the button marked fm.lw mw this will turn on the reciever. then press the button advanced that will change the stations. If nothing happens the cable is broke this is common. u can contact alantic systems in Ma ph# 781-826-8760 this can still be repaired
