Hi everyone,
   As a new member this is my first posted message and I'm wondering if anyone can help with an annoying thing my tv is doing.
 Ever since I purchased the set over a year ago when you turn it on the picture is ok but after a few seconds the picture goes and you get what I can only describe as horizontal interference and a terrible noise.This lasts anything from a couple of seconds to over minute, when the picture returns if you change channels it does it again.When the sets been on a while the problem stops.
While the sets having one of these fits, if you reach around the back and wiggle where the ariel goes into the set the problem stops but as soon as your bum hits the chair it starts again.
We watch sky connected through the scart, this works perfectly and has never had a single flicker of a problem.It just annoys the hell out of me when I see what it does on normal tv.
This is our fisrt B&O tv and even with this problem I wouldn't swap this set for any other make.
We stayed in a holiday cottage in Scotland a few years ago which had a B&O tv and I was blown away by the picture and sound quality, since then I said this is only make of tv would buy from then on. When our old set went, this third or fourth hand MS6000 was the only set my budget would stretch too. But this MS6000 will not be my last Bang and Olufsen tv.
Any information or advice will be greatfully recieved.
  Thanks.
