Latest post 03-06-2010 5:04 AM by Claus. 5 replies.
Page 1 of 1 (6 items)
  • 02-24-2010 5:36 PM
    B&O Beovox S22 Speakers
    Hello,
    I have acquired a pair of Beovox S22 Speakers.  Having never owned anything B&O before, I didn't realise that they have a specific fitting on the back.  I have managed to find what I believe to be the the required cable here http://www.lifestyle-av.co.uk/details.asp?sectionId=4&productId=383 but I was wondering if I am able to connect these speakers to a regular amp?
    Would be very grateful for any information you could shed on the situation!
    Thanks,
    Mike
  • 02-24-2010 6:03 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: B&O Beovox S22 Speakers
    Hi Mike. Welcome to BeoworldSmile
    Yes, these can be used on a non B&O amp, and I wouldn't worry too much about the kind of speaker wire.
    Not sure which connections ar on the S22s, but I imagine it will be the fairly common 2 pin din available to screw or solder on from Maplins etc.
    Do they look like THIS
    Poor me, never win owt!
  • 02-25-2010 3:40 AM In reply to
    Hi - thanks for the quick response and welcome.
    I think they do look like this, yes.  I'm at work at the moment, so will check a bit more thoroughly when I get home, but I think they are the 2 pin din.  If it is any help I have attached a couple of photos of the back of the speakers that were sent to me.
    Thanks for putting my mind at rest that there are solutions out there!  Had quite a panic when I opened up the box!
    Mike
  • 02-25-2010 4:28 AM In reply to
    Yes they have a recessed 2pin DIN plug - you need a 2 pin socket and these are available in a variety of forms at Maplins. These are lovely littl;e speakers - much nicer than the later S25 as the S22 had the more expensive dome tweeter fitted. Very small but a good cabinet finish and very pleasant if lightweight sound. The ones on Beocentral are mine!
  • 02-25-2010 5:31 AM In reply to
    Thanks for the information Peter.  I'm going to pick up some of the 2 pindin cables from Maplin tonight.
    I'll keep you posted on how I get on!
    Cheers,
    Mike
  • 03-06-2010 5:04 AM In reply to
    • Claus
    • Not Ranked
    • Joined on 11-05-2009
    • Copenhagen
    • Posts 41
    • Gold Member
    Mike - the small/round leg on the DIN-plug is "plus"/positive (and the larger/flat one of course "minus"/negative).
    Good luck!
    Claus
    - Claus
    Beolab 5000 (x2), Beomaster 2400-2 & 5000, Beogram 2400/MMC20E, Beovox S30, S45 & S75, M75 - and growing...
