this is a cheap IR to Bluetooth converter for the PS3, but it gets better, if you use a PS3 to play Blu-Ray films on your B&O screen, and you have the Beo5 remote, then the RE-BL X can be used for local IR Distribution for up to four more devices, using the Quad IR emitter cable, and you get proper "Power On / Off" control via the remote
To celebrate the launch of RE·BL X, the RE·BL X Repeater Kit is
available at a reduced EUR 59 (normally EUR 69), when ordered through
the webstore before April 1st
