Latest post 02-22-2010 8:15 AM by Paul. 2 replies.
Page 1 of 1 (3 items)
  • 02-21-2010 10:10 PM
    • Paul
    • Top 500 Contributor
    • Joined on 12-20-2008
    • USA
    • Posts 108
    BM 3000-2 adjusting idle current
    My service manual for my BM3000-2 says to adjust idle current for 100ma.I am not entirely clear on where to measure the current at.Can I just measure voltage across the .15 ohm emitter resistors,which would be 15mv?
  • 02-22-2010 3:56 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: BM 3000-2 adjusting idle current
    Exactly.
    That's the easiest way.
    I would recommend you replace the trimmers if not already done, they are often badly oxidized and/or physically broken.
  • 02-22-2010 8:15 AM In reply to
    • Paul
    • USA
    • Posts 108
    Thanks Martin
    I was thinking of just cleaning the trimmers,but you are right,I might as well just change them.
    Paul
