I have a Sagem ISD91 HD - used to pick up the French TNT-SAT broadcasts, but the PUC list doesn't seem to include it. I've been using it for some time with the box remote, but it would be much more preferable to use it with the Beo4.
Is anyone using this box (as it is relatively quite common in France), and if so, what is the equivalent SAGEM PUC box I should get programmed into my BS3?
As always - thanks in advance.
