Latest post 02-18-2010 4:12 PM by alexb1406. 4 replies.
Page 1 of 1 (5 items)
  • 02-18-2010 9:37 AM
    Cartridge Wiring
    Can anyone tell me what the pin configuration is at the rear of the MMC series cartridges is.  I have just purchased another project and the enamelled copper wiring to the cartridge is all damaged and needs replacing.  The deck is a BG2200 and the cartridge is a MMC20E, though I guess all the MMC series are probably the same.
    I can see 5 strands of wire at the turntable end, 2 for each channel (the two earths are joined together), and the 5th wire is connected to chassis ground.  Does this connect anywhere at the cartridge end?
  • 02-18-2010 11:06 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Cartridge Wiring
    Looking at the rear of the cartridge & going left to right the signal paths are :-
    1. Ground Right
    2, Right
    3, Left
    4, Ground Left
    The turntable ground/earth wire goes to the cartridge body via the slotted hole at the bottom which accepts the spring clip.
    Chris.
  • 02-18-2010 11:50 AM In reply to
    Thanks Chris.
    This now gives me another problem as I am missing the spring clip and the screw to hold it onto the arm.  I assume the clip is held in place by the same screw that holds the cartridge mount?  Has anyone got any going spare?
  • 02-18-2010 2:21 PM In reply to
    • Medogsfat
    • Posts 4,045
    There are 2 types of spring clip used with these cartridge mountings. One is a flat piece of copper & the other is a copper wire bent into a "diamond" shaped hoop (for want of a better description). I'm sure it is possible to make one if you can find some sprung copper - if memory serves me correctly the wire type was the better method.
    Chris.
  • 02-18-2010 4:12 PM In reply to
    Ok, thanks, I'll have to improvise.  Presumably without it it may hum.
