I have a spare MCL2A I'm trying to make sense of in case I need it later. I tried it with a BM5500 I had lying around but ran into local room control problems... first of all, it works just fine with my Beosystem 6500 so there should be nothing wrong with the transceiver, the box, the cabling or my option programming.
With the 5500, the transceiver and the box seem to be working as expected - I can mute/unmute the local speakers connected to the MCL2A with either the transceiver buttons or a remote. However, the Beomaster doesn't do what I try to tell it to do - no volume control, not turning it on or changing a source... however, standby works.
Otherwise I could understand this if the MCL data interface in the Beomaster was broken, but how an earth can it then follow the standby command? Is there something Beomaster 5500 -specific in this setup? The BM is programmed to option 1, and the MCL2A to option 2 as they are supposed to...?
