Latest post 02-05-2010 6:16 AM by xtiand. 4 replies.
Page 1 of 1 (5 items)
  • 02-04-2010 5:44 PM
    • xtiand
    • Not Ranked
    • Joined on 10-02-2009
    • Posts 3
    • Gold Member
    Beosound6 audiobooks
    Has anyone found a source of audiobooks which will load onto Beosound 6 player? I've just bought one and have loaded music on it fine but Audible books aren't compatible.
    The music is great but I would like to be able to have books too.
  • 02-05-2010 1:12 AM In reply to
    • SWISS_2
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Neuchatel, Suisse
    • Posts 552
    • Gold Member
    Re: Beosound6 audiobooks
    Try PANDA MP3.
    There is quite a selection of History, Language, audio stories, available.
  • 02-05-2010 4:20 AM In reply to
    Does BS 6 do the same annoying thing as BS 2 and BM1, i.e. if you listen to an audiobook and stop mid-way in the chapter, it will resume at the beginning of the chapter. Mine do and it's most annoying when you're listening to pod radio where the files may be up to 60 mins long.
  • 02-05-2010 4:35 AM In reply to
    It should be possible to convert the sound file format to an standard mp3 format to play.
    Try -       http://www.nch.com.au/switch/switchsetup.exe
    A free sound file convertion programme.
    Ron
  • 02-05-2010 6:16 AM In reply to
    • xtiand
    • Not Ranked
    • Posts 3
    • Gold Member
    Thanks for the replies, I'll try Panda and the conversion programme.
