Latest post 01-31-2010 10:37 AM by Beowulf. 2 replies.
Page 1 of 1 (3 items)
  • 01-30-2010 7:10 AM
    • Beowulf
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Derbyshire
    • Posts 143
    Beovision 3 32
    I have been offered a Beovsion 3 32 FOC by a dealer, it has a picture fault best described as colour fringing distortion, everything fine other than this! Any ideas if it is worth repairing any easy repair? Any suggstions regarding someone who could repair it in the Somerset Area?
    Kind regards
    Dave
    Beowulf
  • 01-31-2010 5:20 AM In reply to
    • Stonk
    • Top 50 Contributor
    • Marlow, Bucks, UK
    • Posts 1,688
    Re: Beovision 3 32
    Hi Dave,
    Collect it anyway. I have no real idea what's wrong with it but from reading other threads about failing tube problems it is my understanding that normally you get a green or pink hue - not the problems you describe. Therefore it my be an easier fix and hopefully someone else with a bit more tech knowledge will assist.
    I used have a BV3 32. Lovely TV.
    Steve
    If you think nobody cares, try missing a couple of payments.
  • 01-31-2010 10:37 AM In reply to
    • Beowulf
    • Derbyshire
    • Posts 143
    Re: Beovision 3 32
    Hi Steve, I have nothing to lose other than van hire to move it, It diddnt look like tube faliure, just some odd solorization in shadow areas. It has surround modules etc. Thanks for the encouragement!
    Cheers
    Dave
    Beowulf
