Latest post 02-13-2010 12:57 PM by solderon29. 5 replies.
Page 1 of 1 (6 items)
  • 02-10-2010 9:58 AM
    • Dennis
    • Top 500 Contributor
    • Joined on 02-01-2009
    • Denmark
    • Posts 172
    • Gold Member
    AV9000 and MX6000 picture tube?
    Hi!
    I have read that Beovision AV9000 has the same chasis as a Beovision MX6000. Is the picture tube also the same? Will it be possible to mount the picture tube from a MX6000, in a AV9000, if it's the same model?
    Regards Loudspeaker
    I was borned with a Beolink 1000 in my hand!
    Ever seen a Beomaster 6001? I have one! Look here.
    Main system: Beovision AV9000, Beocenter 2300, Beosystem 3500, Beolab Penta MKIII, Beolab 3000, Beogram 6500, Beolink 1000, Beolink 5000, Beolink 7000
    Wish list: Beolab 2,
  • 02-11-2010 7:16 AM In reply to
    • Dennis
    • Denmark
    • Posts 172
    • Gold Member
    Re: AV9000 and MX6000 picture tube?
    Anyone?
    There is standing a little bit about it Here. But nothing about the picture tube!
    Regards Loudspeaker
  • 02-13-2010 6:11 AM In reply to
    • Dennis
    • Denmark
    • Posts 172
    • Gold Member
    Bump!
  • 02-13-2010 7:13 AM In reply to
    I see no reason why not - the tubes did change over time but were essentially the same type. Get the equivalent model and you should be fine. It will no doubt require quite a bit of setting up though once fitted.
  • 02-13-2010 11:33 AM In reply to
    • Dennis
    • Denmark
    • Posts 172
    • Gold Member
    Thanks for your reply, Peter!
    Anyone else with an input?
    Regards Loudspeaker
  • 02-13-2010 12:57 PM In reply to
    Curiously,it's a different part No for the crt in the AV9000,although it's prolly just an admin anomaly?Type A66EAK220X02 seems to have been used across all the various "42" type chassis that I've come across.I can't see any difference in the two circuits.I would recommend swapping 'tubes complete with their respective scan coil assemblies to ensure best geometry.I don't fancy dealng with the mechanical curtain mech tho!
    Regards,
    Nick
