Latest post 01-27-2010 5:44 AM by Hiort. 3 replies.
Page 1 of 1 (4 items)
  • 01-25-2010 4:35 PM
    BeoCom 2 MK 1 and MK 2 difference
    I recently bought a BeoCom 2 phone from my local stockist. After looking through the website I noticed that it is a MK 1 model.  Can anyone tell me the difference between the MK 1 model and MK 2 model?
    Also, can these BeoCom 2 phones connect to any DECT base station, as I currently have a BT one?
  • 01-25-2010 4:40 PM In reply to
    Re: BeoCom 2 MK 1 and MK 2 difference
    If I recall correctly, the MK1 need to be firmware upgraded, to be able to work with a separate base.
    MK2 already has that functionality. The upgrade is a minor thing and your dealer will do it for you.
    Would guess less than 50 eur.
    _____________
    Happy owner of: BV10, 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11
    1:st prize winner Beoworld January Price Draw.
  • 01-26-2010 1:35 PM In reply to
    Thanks for that!
    Would having a MK 1 influence connecting to a another DECT base station for example a BT one?
  • 01-27-2010 5:44 AM In reply to
    I´m not sure regarding connection to other DECT base.
    I know that an upgraded MK1 cannot connect to the new beoline base. It has to be the "square" one.
    http://www.beoworld.org/prod_details.asp?pid=1234
    _____________
