Latest post 01-25-2010 4:20 PM by macjonny1. 3 replies.
Page 1 of 1 (4 items)
  • 01-25-2010 10:47 AM
    BeoVox CX-100 or BeoLab 6000 for surround
    Hi all,
    In anticipation of the upcoming surround-sound-capable BV 10 to the States, I'm contemplating speakers to hook up for rears. My choices have boiled down to the CX-100 or BL 6000 for economic reasons. I have a pair of CX-100 in storage (which have had their foams replaced about 8 years ago), so all I should need is a $150 powerlink amplifier and $60 STB wall brackets to make them work. On the other hand, the BL 6000 are beautiful and are approx. $1000 second-hand. Not taking into account the cost, which of these two might sound better? The main speakers are BL 9.
    Thanks, Leo
    BV 10-40, BV 8-32, BL 9, BL 4, CX100, BS Ouverture, BS 2000, BG 4500, Passive, LC 1, A 9
  • 01-25-2010 1:54 PM In reply to
    • akoro
    • Top 500 Contributor
    • Joined on 08-07-2008
    • Espoo, Finland
    • Posts 88
    • Gold Member
    Re: BeoVox CX-100 or BeoLab 6000 for surround
    As surround sound is all about ambience your systems quality depends a lot of the speakers placement. If you can place BL6000 properly they will be far better choice. Then again I prefer surround speakers placed higher than normal speakers so CX-100 placed on the wall might give better feeling to movies compared to BL6000 on floor.
    BeoLab 4000 would be something to consider as well and if your budget can handle: BeoLab 3 is really good choice, ALT all around.
  • 01-25-2010 2:23 PM In reply to
    I think CX100s would be a perfectly good short term solution - in fact you may well find that they all you need. I will be very interested to hear how your system performs.
  • 01-25-2010 4:20 PM In reply to
    I recently mounted all of my BL6000s which I have in the front and the back.  They are awesome on the wall and sound much better than on the floor firing into the couch.
