I bought a BV 8- 40 befor Cristmas, and I am happy with it, but I have some questions however:
If you set  it up with a sub, front and rear speakers in a 5.1  does the signal sendt to the speakers change when you select different spekers. For exampel will  more of the low frequency go to the Sub when you have “small”  speakers ?
In the service menue  where you find the Film Mode  on/off, there are several  adjustments.Is there a manual for this, or short description of what this means?
I have also connected a PC to it via HDMI (1920*1080), but I am not completely sattisfied with the picture. It seems to be some mud around tellers. If I use the VGA input it is perfect exsept that I only get 1280*720 resolution.  If I increase the resolution the picture will not use the compleate screen.
I also have the ML –module and have connected an Ouverture. Is it possible to program the TV/Radio to start / stop at predefined times. Before I had a MX8000 and then I could program this quite easy.
Tom
