Latest post 01-13-2010 11:14 AM by Peter. 4 replies.
Page 1 of 1 (5 items)
  • 01-12-2010 9:30 PM
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    What is the replacement for a BeoLink 5000?
    My B&O store tells me the closest new replacement for this remote is the BeoLink 1000 which they obviously still have in stock. I don't agree with this and would have thought the BeoTime was the replacement > any thoughts?
  • 01-13-2010 1:34 AM In reply to
    Re: What is the replacement for a BeoLink 5000?
    As far as I'm concerned there isn't any replacement. B&O dropped it when they discontinued 2 way communication. Of course the Beolink 1000 works well with equipment that can be controlled with a Beolink 5000, but without 2 way communication, it's not the same...
  • 01-13-2010 1:43 AM In reply to
    True, there is no replacement to BeoLink 5000, since 2-way communication was discontinued with the remotes; design-wise, the Beo4 is the closest you could get to the 5000, operation-wise you could go for a second-hand BeoLink 7000 if you want to keep the 2-way capabilities.
    What products are you going to use with your remote control?
    Reunion Island is greeting you!
  • 01-13-2010 7:08 AM In reply to
    The Beolink 5000 was still available from dealers no so long time ago. p.
  • 01-13-2010 11:14 AM In reply to
    The Beo4 was the replacement though you lose some features. The BL5000 is however still available, as Phil says. The BeoTime is not a very useful remote control! Good timer though!
