Latest post 01-10-2010 11:52 AM by GANGO. 3 replies.
Page 1 of 1 (4 items)
  • 01-10-2010 8:33 AM
    • GANGO
    • Not Ranked
    • Joined on 04-17-2007
    • italy
    • Posts 48
    ibundo pro to beosystem3- how to connect ?
    hello all,
    i purchased recently this http://www.lfd.de/ibundo-w.html docking station for i-pod and now i would like to know how to connect it to my beosystem 3/bv9. the dock is switching on by pressing a.aux on beo4/5 , but a.aux on my setup switches on the bs 2300 connected to the bs3. how can i connect the ibundO pro in a different way ?
    grazie
    gango
    gango
  • 01-10-2010 9:04 AM In reply to
    • madskp
    • Top 500 Contributor
    • Joined on 11-06-2007
    • Denmark
    • Posts 111
    • Gold Member
    Re: ibundo pro to beosystem3- how to connect ?
    Not knowing the specific product I guess the easiest solution would be to connect it to the AUX port on the BS2300
  • 01-10-2010 11:03 AM In reply to
    Suggest you ask the company that sells this. You could designate the 2300 as something else I suppose.
  • 01-10-2010 11:52 AM In reply to
    • GANGO
    • Not Ranked
    • italy
    • Posts 48
    the aux port on the bs2300 is already occupied by the ML cable....Sad
    gango
