newbeo:
I am loking to buy my first B and O, looking at the beocenter 8500, 9500 or 9300, any ideas as to whcih I should go for? Thanks
9300 has an inferior tape deck, but if you don't plan to use it much (or not at all), the rest of the machine will be more serviceable, and potentially quite a bit newer to begin with than a 9500.
8500 is a bit pointless as it is mostly just 9500 with some artificial limitations, unless you actually happen to like the dark gray panels more - I know I like those on my 8000. But you seldom see those on sale anyway.
Welcome to the forum
