Latest post 01-10-2010 9:13 AM by Hughie. 2 replies.
Page 1 of 1 (3 items)
  • 01-09-2010 4:37 PM
    Beotalk 1200 wont record announcement or message
    Hi. I bought the Beotalk 1200 privately. When trying to record an announcement I push the middle button to record a message the timer counts while I speak. But when I push it again it flashes 0:00 and there's a click and a  dash (-) appears to the left of the screen for a few seconds before the time and date re-appears. When I call to test, it rings and picks up but no announcement is heard. I leave a message and hang-up but nothing flashes on the Beotalk to suggest a message has been recorded. Any ideas? Thanks very much for any help you can give.
    Filed under:
  • 01-10-2010 6:17 AM In reply to
    Re: Beotalk 1200 wont record announcement or message
    Hi You can search these forums to learn how to master reset the machine (can't remember offhand). Failing that you might need a new circuit board. I've just had one fitted costing approx £130.
  • 01-10-2010 9:13 AM In reply to
    • Hughie
    • Not Ranked
    • Joined on 04-17-2007
    • Walton-On-Thames
    • Posts 38
    sounds a bit like the problem I had with mine some time ago - and yes I also needed a new circuit board at a cost of about £120+ - loathed to pay it but I did and it has worked fine since then - I actually really like the beotalk 1200, lots of features and relatively easy to use - after spending a little (a lot actually!!) of time reading the manual Wink
    regards, Hugh
