Latest post 01-04-2010 3:51 PM by lausvi. 3 replies.
Page 1 of 1 (4 items)
  • 01-04-2010 1:50 PM
    Beovision mx 3000 turn on volume problem
    Hi
    This is my first post here, I hope i will not sound too funny with my problem
    I just got third-fourth hand mx 3000 with ASWO 3216 remote
    It works great, but when I turn it on, volume is loud, about half scale
    It's a problem at night, i have to mute it the moment i turn it on
    How to fix this?
    How to acess service menu?
    Filed under:
  • 01-04-2010 2:03 PM In reply to
    • lausvi
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Helsinki - Finland
    • Posts 498
    • Gold Member
    Re: Beovision mx 3000 turn on volume problem
    Welcome to Beoworld!
    You mean you don't have a B&O remote for it? (Beolink 1000 or newer). The syntax for storing the sound settings is: set volume to preferred level and then press STORE - SOUND - STORE. Don't know about other remotes, though.
    The user manual is available on the site for bronze or golden members.
    Bang & Olufsen - The art of controlling sound, picture and light
  • 01-04-2010 2:13 PM In reply to
    I dont have beolink, but this is a good replacement, so i figure that will work
    Thanks for ansver and for welcome note
  • 01-04-2010 3:51 PM In reply to
    • lausvi
    • Posts 498
    • Gold Member
    You're welcome! Yes -  thumbs up
    If the replacement remote is for B&O it should have all the required buttons. It will be far from the Beolink 1000 in terms of quality, though!
    By pressing SOUND you can access the treble, bass and balance adjustments, too. Color and other settings are found under PICTURE, and when you are happy with the settings, STORE-PICTURE-STORE.
