Latest post 01-03-2010 4:21 AM by Movie. 3 replies.
Page 1 of 1 (4 items)
  • 12-29-2009 6:29 AM
    • k984942
    • Top 500 Contributor
    • Joined on 11-10-2008
    • London, UK
    • Posts 194
    Lost STB!! HELP!
    Hi All,
    I have a big problem I'm hoping you can all help with!
    For some reason I can no longer see or control my V+ box since Masterlinking my Avants.
    I can see and control the DVD1 (attached to the AV scart of the master Avant) on the master and the link TVs
    I can't see or control (via the STB-C) the V+ box on any of the TVs. Its plugged into the Decoder scart on the back of the master.
    If I put the V+ scart into the AV scart port then I can see V+ when I hit 'DVD' on the Beo4, but can't control it.
    Any ideas guys? I've tried unplugging the masterlink and switching off the master Avant from the mains for 15 minutes.
    No Joy!
    32" RF VCR Avant, 2 x 28" VCR Avant, DVD1, Beocom 6000, Beo5, A9 Keyring!
  • 12-30-2009 8:17 AM In reply to
    • Movie
    • Joined on 04-18-2007
    • Posts 90
    Re: Lost STB!! HELP!
    Make sure you connections are not loose.
    Have you registered your STB to the correct scart input.
  • 01-02-2010 9:59 AM In reply to
    • k984942
    • London, UK
    • Posts 194
    Managed to sort the problem now.
    It looks like when I changed the master Avant's option, it messed up some of the SCART mappings.
    All good now!
    Thanks for your help Movie
  • 01-03-2010 4:21 AM In reply to
    • Movie
    • Posts 90
    Glad you got sorted.
    Movie
