1st March February 2012
Latest post 12-22-2009 3:31 AM by John. 22 replies.
12-16-2009 9:30 AM
John
- Joined on 09-20-2009
- BRISTOL UK
- Posts 62
Beogram 3000 (Tangential version)
Can anyone help with suggestions? I recently acquired a Beogram 3000. Mainly for the looks, but as it is complete and looks sound I tried to run it.I have not linked it to any of my equipment but am not having any success. Using the button controls the motor starts to move but the platter stops after only moving a mm or so. The pickup indicator shows the speed indication and the pickup slides freely. The platter seems to be locked and does not turn at all.
It does rock to and fro a mm or so but seems to be locked by some sort of springy lever. I have opened the deck and as a start removed the drive belt to confirm it is not the motor and also to avoid damage. There is nothing obvious preventing rotation so I wonder whether there is an interlock somewhere that is not being activated or else out of adjustment. The service manual does not give a description of what should happen so I think I might have to do something rather involved.
Can anyone suggest where I should start ? I have two concerns, the first is I don't want to be looking for a problem if there is an interlock active without the plug connected and so nothing is amiss, second as it seems locked with some plastic lever I don't want to break something by forcing things. I am also puzzled by it being locked anyway. Most decks I have come across have the platter completely free and though they might be stiff due to dried grease they never lock rigidly.
(The only time I have seen anything similar is with a faulty gearbox when two speeds were simultaneously selected.)
Many thanks John
Stoney3K
- Joined on 10-26-2007
- Eindhoven, NL
- Posts 91
Re: Beogram 3000 (Tangential version)
Maybe you should put an actual record on the platter? The tangential Beograms have sensors in the platter that determine which record size (7", 10", 12") is being used and set the arm position and platter speed accordingly.
If there's nothing on the platter, the unit will stop and return to its home position.
joeyboygolf
- Joined on 04-16-2007
- Ely, Cambridgeshire, UK
- Posts 3,252
If the stylus is any good I suggest that you remove it for safe keeping while you sort out the platter problem.
With or without mains connected, you should be able to turn the platter MANUALLY in a clockwise direction for ever. If you cannot do so then something is jammed in the gears under the platter.
If you can turn the platter freely clockwise then put a scrap record on the turntable and press <TURN. The arm should move and hover over the lead in and the platter should spin at the nominated speed for that size of record.
If all is well. press STOP. The arm should return to the park position and the platter should stop.
Now press PLAY!
Stoney3K
- Eindhoven, NL
- Posts 91
joeyboygolf:
You might want to put the stylus back first at this stage though, otherwise, you'll have a very quiet evening!
rayinrubber
- Joined on 05-10-2007
- Hamburg
- Posts 28
I completely agree with Graham,
FIRST store away the stylus safely, then try to run any old record to force the deck to recognise size and accordingly speed.
I did not understand a part of your post where you said that "second as it seems locked with some plastic lever"?!? Can you actually see something jamming the gears?
And (hope you checked that already ;-) finally: there is a transportation lock on that deck. Its a screw on the bottom, which fixes the platter/plattersuspension. Did you unlock that one?
John
- BRISTOL UK
- Posts 62
Thank you for the replies. Graham I think you have confirmed that I have a problem. I have removed the cartridge so I can push things around a bit. The platter does not move in either direction and when I remove the drive wheel the two large gears are rigid. The pickup arm is free and can be slid along it's guide rail.
I have just looked at the service manual and section 5-1 appears to show the starting gears of the gear train. The wheel they call the camwheel can be released by the toothed sector being moved as is described for the adjustment. It then rotates freely but not very far before engaging with some other mechanism. It certainly looks as if I must examine these gears in detail and also very carefully.
Regards John
John
- BRISTOL UK
- Posts 62
Yes, I did release the transport screws and the chassis is floating free. Are these transport screws the transport lock mentioned earlier or is there something else?
John
rayinrubber
- Hamburg
- Posts 28
yes that is the lock I mentioned.
joeyboygolf
- Posts 3,252
John:
Regards John
Take the drive belt off. Remove the black plastic circle (don't know what that does - the deck works just as well without it!!!)
Lift the under platter vertically upwards and carefully lay it to one side.
It sounds like your cogs have got their knickers in a bit of a twist so you may now be able to sort them out. Gently mind, 'cos spares are not available unless you buy another scrap deck!!!
John
- BRISTOL UK
- Posts 62
Thanks Graham,
I have now got to this stage and will try to sort the gears with the help of the assembly pictures in the service manual. It is obvious that care is needed with all the plastic bits that will not like abuse.
One thing I have confirmed is that the motor is O.K. and that it changes speed with the manual selector. I have noticed that the grease on the pickup carriage is dried and although I doubt it is the problem as the drive comes from the gearing connected to the platter giving it a clean might help.
It is a shame about spares but I got this deck as a possible source of bits for a Beogram 5006 that is working fine at the moment. Unfortunately I have the vintage radio disease and cannot resist restoring sets bought as scrap for spares. I will obviously have an absorbing time learning "reverse engineering"
Regards
John
yachadm
- Joined on 06-24-2007
- Jerusalem, Israel
- Posts 687
John
Do not start playing with the gears - that's not the source of your problem.
Read this post - your problem is the bad plastic piston - no spares, and needs to be rebuilt.
http://forum.beoworld.org/forums/p/24078/183590.aspx
If you're up to rebuilding it yourself - great, if not, disconnect the main PCB with the solenoid on it, and send it to me for a rebuild.
Menahem
Learn from the mistakes of others - you'll not live long enough to make them all yourself!
John
- BRISTOL UK
- Posts 62
Many thanks for the link. So far I have looked very carefully at the gears but not attempted to remove anything. I have read through the contributions in the thread and will look at it very carefully to check the operation. I had overlooked this relay as something seemed to move there when I switched things. The symptoms are just as described so this is most likely to be the problem. I have someone who is a vintage camera enthusiast so I stand a good chance of fixing it. If not I will remember your kind offer.
Regards
John
John
- BRISTOL UK
- Posts 62
Menahem.
I removed the PCB to check the solenoid and all seems well. The plunger is completely free and can be moved easily by hand from one end of the slot to the other (about 7mm) . I have not tried it with power but as it actually moved a little when in position I assume the coil is fine.
Movement when in place is limited by the two levers resting against the ends of the plunger. They are in fact quite rigid and neither can be moved at all. I would have thought that one should be free but have not yet found out how they should operate. Closer inspection is needed. I am reluctant to remove any of the gears to see what is happening without understanding how they should work. With the PCB removed I might be able to see more.
Regards
John
Dillen
- Joined on 02-14-2007
- Copenhagen / Denmark
- Posts 5,008
Will the tonearm carriage move sideways if pushed gently by hand or is it locked too ?
Dillen
- Posts 5,008
Can you lift off the subplatter ?
If so, can you rotate the two cam wheels by hand using no more than "controlled hand-force" ?
John
- BRISTOL UK
- Posts 62
Martin,
Yes I have removed the sub-platter and I have checked the cog wheels. They all seem free on their spindles but there are two with green plastic slides that I assume are the cam wheels. These are free but cannot be rotated more than a degree or two before giving the impression that there is some locking mechanism preventing further rotation. There is another wheel that is smaller and appears to have a gap in the teeth. This rotates a bit more, it has a section of teeth that are shallower than the others and when the teeth engage in the large wheel ( with the slider) it stops.
John
yachadm
- Jerusalem, Israel
- Posts 687
Failing any mechanical problems, or broken parts, I still would focus on the plastic piston.
I had one come back, about 2 months after I repaired it, and I could not believe that the piston was still the problem. After all, I figured that I had rebuilt it perfectly, and it moved easily when I pushed it with my finger.
Turns out that I had not lubricated the tunnel enough, and it was sticking. I sprayed some more Silicon Spray in, then wiped it down, and it hasn't come back again.
So the fact that your finger can push it easily, does not necessarily mean that it's slippery enough to be activated by the very low current in the solenoid.
IIRC (I don't have one on the bench now), you must notice that the solenoid moves at the instant that you push the PLAY button. If it doesn't, then the solenoid or its associated circuits are most likely the source of the problem.
Menahem
Eugene
- Joined on 12-17-2008
- Posts 589
I will second Menahem on that. I my case it was a bit too much silicone grease and I had to take some out
John
- BRISTOL UK
- Posts 62
It looks as if I must look at the solenoid again. I am a bit puzzled about what is supposed to be happening. I have removed the PCB to check the solenoid and can not see what the bell cranks at each end do. They do not move very far but disappear under the cam wheels. The mechanism seems related to moving the pickup arm to the correct starting point and then lowering it to the record. At this stage it should all be free from the gear on the sub-platter so that the record can turn freely. The cam wheels do not run free and I can not see why. Perhaps I am overlooking some interaction with the record weight sensor.
The whole thing is fiendishly ingenious and if I ever resolve it I think I might feel rather satisfied.
If I can't solve the problem I can always revert to my original purpose and use it as spares for my other deck if that ever fails. I did have a suggestion to open up the other deck as a reference to see what should be happening. My experience so far tells me not even to think about it. The other deck works fine but the opportunities to wreck it seem endless.
John
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
John:
I'm sorry I can't help you with your problem, but I just had to say that this is a feeling you better get accustomed to if you plan to work with B&O turntables
Season's greetings in any case - and remember that they were built by a human! Resist the temptation to wreck it and you will eventually work it out...
John
- BRISTOL UK
- Posts 62
Thanks for the good wishes, as you say, it was made once and so as there are no broken parts it must be possible to get it to work again.
One idea is that I could follow a scheme I had as a child trying to learn about clocks :- take out all the parts and put it together again-. The trouble is there were always bits left over. If I tried it with this I suspect I would have enough bits left over to make a tape deck as well.
The good news is that I am seeing a glimmer of light, even if it is only at the beginning of the tunnel.
Seasons Greetings to all.
John
Page 1 of 1 (23 items)
