Latest post 12-25-2009 5:15 AM by Hiort. 2 replies.
Page 1 of 1 (3 items)
  • 12-21-2009 5:31 PM
    Messed up Beo4
    Got the new Beo4 with V-AUX button, but cannot figure out how to config it to work with my setup.
    Main room:
    BV8 with cable box (used v-aux from "LIST"  with my old remote.
    and
    Beosound 3000
    The BS3000 command work fine but cannot get the commands to the BV8.
    Any hints?
    /Claes
    _____________
    Happy owner of: BV10, 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11
    1:st prize winner Beoworld January Price Draw.
  • 12-22-2009 1:46 AM In reply to
    Re: Messed up Beo4
    Understand from the BV8 manual that "config" "video" shall be set to "video 2" but still not working with the tv.
    Do I need to adjust "option" also?
    _____________
  • 12-25-2009 5:15 AM In reply to
    Re: Messed up Beo4
    I simply unplugged the TV set for a while.
    When restarted it worked just fine again, with the new remote.
    Case closed.
    _____________
