Latest post 12-22-2009 6:13 AM by beo4me. 10 replies.
Page 1 of 1 (11 items)
  • 06-27-2009 2:17 PM
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Western Digital Media Player
    Anyone has already creatred the file? It would be very helpful as I do not have the equiment to create it.
    Best regards
    Spiros
    Best regards
    Spiros
  • 06-28-2009 9:45 PM In reply to
    Re: Western Digital Media Player
    Hey there spiros , yes there is a file already Created by Keith some time ago  when i needed it  myshelf  ;)  should be on beo5 forums somewhere , if u cant get it let me know so i sent it to u ....
  • 06-29-2009 4:35 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Just got it!!! Many many thanks for the tip.
    Best regards
    Spiros
    Best regards
    Spiros
  • 07-02-2009 3:42 PM In reply to
    No problem mate !
  • 12-20-2009 6:09 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    due to change of computer I lost the file :(
    Anyone could please resend it????
    Thanks for all the help
    Best regards
    Spiros
  • 12-21-2009 1:55 AM In reply to
    can anyone send me the file for the Western Digital Player to !!! please
  • 12-21-2009 7:30 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Dear Keith any chance you might have it somewhere?!?!?!!?
    Best regards
    Spiros
  • 12-21-2009 8:04 AM In reply to
    You think this points to it?
    Cheers,
    Frank
  • 12-21-2009 8:11 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Hello Frank,
    Many thanks for this!!!!!!!!!!!
    This is the one!
    Best regards
    Spiros
    Best regards
    Spiros
  • 12-22-2009 3:47 AM In reply to
    Frank, thanks for the link...
    I have two question for this?
    1. can i the xml file import in the Beo5 Confinc Tool and load this in my beo5??
    2. can i controlled the WesterDigtal HDPlayer directly from the Beo5 or i need a translaterbox like the Lintronic or IRTrans, because in the STB Libary of the Beovision TVs is not a PUC for the WDPlayer???
  • 12-22-2009 6:13 AM In reply to
    windmacher:
    1) Yes, just copy the XML file to the ThirdParty directory of your Config tool installation...
    2) Direct control, see my other reply in the German forum.
    Cheers,
    Frank
