Latest post 12-28-2009 12:04 PM by mjmedlo. 3 replies.
Page 1 of 1 (4 items)
  • 12-27-2009 3:15 PM
    Are any of you using two sets of surround speakers?
    I was just curious how many people here are using a 6.1 type setup where you have the front R&L, center, surround L, surround R, and back surround channels like the BS3 supports?  If so, what speakers do you use for the 2 surround channels?  have you noticed much difference from just using one pair of surround speakers?
  • 12-28-2009 11:23 AM In reply to
    Re: Are any of you using two sets of surround speakers?
    No one here has a 7 speaker setup?
  • 12-28-2009 11:52 AM In reply to
    macjonny1:
    Well, I do run one in a non B&o setup (7.2)... the additional channels don't seem to get much of a work out unless the source included them... maybe 5-10% of what I watch?
    As far as my B&o setup... I actually reduced from 5.1 to 3.1...
    • B&o bottle opener
  • 12-28-2009 12:04 PM In reply to
    • mjmedlo
    • Top 150 Contributor
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    I have used a 7.2 set up.. .
    I used lab 5s up front with a 7-2 center. .. BL3s as surround and 6ks as rears .
    the rears get less sound than any . .
    Honestly most movies/media don't support 7 channel audio so the BS3 "makes up"
    the difference. . You get some sound from them but not much. .
    I have gone back to 5.2 with all ALT speakers now.
    Hope this helps.
    MJM
    I'm ready for something new that I actually want to buy!
