Latest post 12-20-2009 3:29 PM by tournedos. 3 replies.
Page 1 of 1 (4 items)
  • 12-20-2009 11:47 AM
    • naphi
    • Not Ranked
    • Joined on 12-20-2009
    • Posts 7
    Beovision MX4002 compatible with ps3 ?
    is there anybody who can help me with the following problem:
    i am just on vacation and at my hotel room i have a b&o beovision mx4002 - now i wanna know if its possible to activate my playstation3 at this tv.
    if yes, could anyone please explain the exact way to do that - starting how to activate the av-channels etc.
    hoping for helpful answers,
    best regards
  • 12-20-2009 11:54 AM In reply to
    Re: Beovision MX4002 compatible with ps3 ?
    We would need to know what kind of a remote you have - does it have a MENU button for example? If it doesn't, or if nothing happens when you press it, it is quite probable that either the remote or the TV (or both) is a special hotel version. In that case, it might not be possible to select or do anything else than what the hotel wants you to do with it.
    -mika
  • 12-20-2009 1:52 PM In reply to
    • naphi
    • Not Ranked
    • Posts 7
    hi there,
    thx for the quick reply.
    the remote has a menu button - i already tried on my own to fix the problem but i am not too good at installing such things.
    after pressing the menu button i could choose between tvprogramm list, sound, picture and setup - if i choose setup there are tuning, timer, clock and sockets - in sockets options i could turn on some options für "PL" "AV1" "AV2" and "S-VHS"
    any ideas ?!
  • 12-20-2009 3:29 PM In reply to
    In the sockets menu, goto for example AV1, set it to show "V.TP-1" (or some such, for "video tape recorder 1" anyway). Then when you connect your PS3 to AV1, you should be able to select it with "V.TAPE" on the remote.
    If this doesn't help then I'm afraid I can't advice any further, must be something specific for the PS then (I know nothing about them).
    -mika
