Latest post 12-19-2009 12:40 PM by stefan. 6 replies.
Page 1 of 1 (7 items)
  • 12-18-2009 3:10 PM
    Tuning an MX 4000
    Hi all:
    Does anyone know how to tune an MX 4000. I have just powered one up and it has preset station labels etc but there is no reception from the portable antenna I have. This could be because the reception is so bad in Cambridge. However, I cannot see in the menus the option to scan or reset tuning. Is there this option and how do I get to it?
    Graham
  • 12-18-2009 3:22 PM In reply to
    Re: Tuning an MX 4000
     Using Beolink 1000 GOTO to input a specific number such as 400 to start then >> . When station is tuned press STORE/Ch Number/STORE then >> for the next station.
    Regards Graham
  • 12-18-2009 3:29 PM In reply to
    Hi Graham:
    Thanks, I only have Beo 4s is there a workaround?
    Graham
  • 12-18-2009 3:57 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    V.SETUP - GO - TUNE - >>....(?)
    Stefan
  • 12-18-2009 7:47 PM In reply to
    Hi Stefan:
    Sorry how do I get the V.Setup option?
  • 12-19-2009 7:15 AM In reply to
    Tray this manual MX4000 UK
    My Bang & Olufsen....
    • BeoCenter 2 DAB/DVD mk.II
    • BeoVision 7-40 DVD mk.III
    • BeoLab Penta mk.III
    • BeoLab 4000 icepower
    • BeoLab 4000
    • BeoLab 3500
    • Beo 5
    • Beo 4 mk.I & mk.III
    • Beocom 6000
    • A8 Earphones
  • 12-19-2009 12:40 PM In reply to
    • stefan
    • Posts 1,733
    Graham1982:
    Hi Stefan:
    You can add V.SETUP to Beo4 List. Press STANDBY and LIST . ADD? should be displayed. Press GO and search for V.SETUP. Press GO again. Now it`s on the list.
    Stefan
