Latest post 12-21-2009 9:56 AM by mjmedlo. 4 replies.
Page 1 of 1 (5 items)
  • 12-19-2009 3:20 PM
    • mjmedlo
    • Top 150 Contributor
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    upgrade screen in a bv-9
    I can get my hands on a bv-450 screen pretty reasonably . . .the acm model
    Can I install that screen in my bv9 somehow?
    is that a real complicated procedure?
    thanks
    MJM
    I'm ready for something new that I actually want to buy!
  • 12-20-2009 3:39 AM In reply to
    Re: upgrade screen in a bv-9
  • 12-20-2009 2:42 PM In reply to
    • mjmedlo
    • Arkansas, USA
    • Posts 384
    MK?
    i have a d-8 i think. . .a 720p early model
    it's incredible but i can get that bv4 panel pretty cheap if
    i can put it in here i figure i might as well ..
    can i make the acm work? just a bs3 upgrade i'd assume??
  • 12-20-2009 3:05 PM In reply to
    MK I then, first model
    I dont know if there is any different between BS3 models
    you must check this with your dealer, so you can get 1080p full HD
    If not there maybe will not be any improvement to swap panel
  • 12-21-2009 9:56 AM In reply to
    • mjmedlo
    • Arkansas, USA
    • Posts 384
    I would think I could just upgrade teh software of the BS3 to show that it's a d-11(??) panel and it should work?
    Has anyone done this?
