Hi Alistair,
I honestly do not remember, but it was not significant, nothing like shipping the whole deck at $380. (One way) Customs fees did not apply as I shipped it under their value radar.
FORGET the challenge of doing it yourself. Trust me on this, I did the entire cap kit and still nothing worked. Martin found hundreds, yes hundreds of solder points that were bad, and all looked perfectly fine to me.
True, this was on an older Beogram 8000, but still you are likely to be in much the same point.
If you are into soldering, well fine, but remember you have to be oh so carful not to put too much or too little and you have to be careful not to damage the caps and transistors.
I did a LOT of work on my shattered (in transit) Beogram 4000 and that was a challenge, But I didn’t do any of the caps.
It is your call, but if it were me, I’d ship the board to Martin.
Jeff
