If you set your BS6500/7000 to A.OPT 1 and the Avant to V.OPT 1, you will activate the Avant by selecting a video source - TV, DVD, DTV, V.MEM....- without affecting the BS6500/7000. Vice versa activate your audiosystem incl. Pentas by RADIO, CD, PHONO, A.TAPE without affecting the Avant. If you want TV sound on your Pentas just press AV - TV (DTV, DVD....) to activate your BM 6500/7000 and the Pentas.
But the "classic" AV setup is Avant V.OPT 2 (your Pentas are connected to the Avant) BS6500/7000 in A.OPT 0 (no speakers connected). Presing RADIO, or any other audio source will activate the selected source, the Beomaster, the Avant (in audio mode) and the Pentas. Selecting a video source will activate the videomaster (Avant) and Pentas, connected to Avant`s Powerlink.
Benefits:
- you can access all your audio- AND video sources via masterlink in link rooms.
- It is also possible to create a mix of ML- and MCL system.
- Integration of audio- and video.
Stefan
