I have a Beovision Avant RF DVD that has developed thin horizontal straight green lines across the screen (evenly spaced and on a slight angle ie not quite flat) , with a green vertical band down the sides. It is there only when the screen is on ie when watching tv or a dvd and they disappear when the tv is turned off...
Does this mean the tube is going to die???? Or is it just a setting issue???
Can anyone help?
My B&O: 2009 Catalogue and Pricelist
