Hi Emmanuel,
Thanks for the good work you have already done.
By the way, what do you think of adding a new section called "Beoworld Meetings" or "when Beoworlders meet together"
In the past, we used to have such a section like this in the former forum. Then it would be great to renew the concept.
We can divide the major section in smaller ones according to where beoworlders are coming from :
-  Scandinavian Beoworld Meetings
-  French Beoworld Meetings
- American Beoworld Meetings
- etc. for example
I will be pleased to have your (and all of you) thoughts about this matter.
Cheers,
Guy
									    --= "Everything gets done with Patience" =--
--= "Less is More" - Mies Van der Rohe"
--= BV10 46", BL8K, BL4K, BL2, BS Ouverture, BC6000 (Mk3), BT1100, Beo4 , A8 and ...the Atomic Floyd "Airjax+Mic" earphones =--
