Latest post 12-08-2009 3:59 AM by pfroche. 2 replies.
Page 1 of 1 (3 items)
  • 12-02-2009 5:27 AM
    connecting 7-pin DIN to 5-pin DIN
    Hello - a simple but crucial info: the BeoWorld FAQ suggests to use a 5-pin-DIN to 4 RCA adapter to connect a non B&O products to my Bang & Olufsen's 7-pin DIN socket. But how do I connect the B&O 7-pin DIN to a 5 pin DIN? Does this require another adaptor?
    Thanks for your help
    P
    Filed under: ,
  • 12-02-2009 5:46 AM In reply to
    Re: connecting 7-pin DIN to 5-pin DIN
    If it is a socket, just use a 5 pin plug - the extra 2 pins are not going to be used. If you have a product with a 7 pin lead, the bottom two pins unscrew - just keep them safe somewhere!!
  • 12-08-2009 3:59 AM In reply to
    Thanks Peter, mystery solved.
    Patrick
