Latest post 12-16-2009 6:39 AM by PhilLondon. 1 replies.
Page 1 of 1 (2 items)
  • 12-16-2009 6:14 AM
    BeoLink PC 2 - no firmware upgrade possible
    I own a BeoLink PC 2 since ages - and it still runs on the original firmware it came with, version 1.18. I tried to upgrade the firmware using BM-Link, but it failed with the error message
    "There was an error updating the firmware. The following error was reported: Failed to write data".
    Is there a way to fix this - apart from buying a new Beoport?
    Thank you and best regards
    Stefan
  • 12-16-2009 6:39 AM In reply to
    Re: BeoLink PC 2 - no firmware upgrade possible
    I would try and install the free Beoport/Beoplayer on a PC and do the update from there. Or take it to your dealer, they always have a PC with Beoplayer on it.
    p.
