Latest post 11-22-2009 4:27 AM by Nickyg63. 4 replies.
Page 1 of 1 (5 items)
  • 11-21-2009 3:23 AM
    • PH
    • Not Ranked
    • Joined on 11-19-2009
    • Posts 16
    BV 7-40MKII and Penta speakers
    Hi all. Have just got DVB-T MPEG4 module buildt in my BV7-40MKII. It works, but now my Penta speakers is WRITING V-SAT instead of DVB, how can that be? Speakers connected to BV7, and speaker display=orange light. Thanks PH
  • 11-21-2009 5:45 AM In reply to
    Re: BV 7-40MKII and Penta speakers
    Yes it is entirely right to do it.
    It has something to do with the software built into the BeoLab Penta.
    I even have a BeoVision 7-40 mk.III and BeoLab Penta mk.III and write the SAT in dispalyet when I see DVT. And when I watch a DVD, then write the CDV in dispalyet. And when I watch a DVD from my BeoCenter 2 mk.II then writes the V.TP2.
    So you see there is nothing unusual in the. But really it would be super if it wrote the real source of Penta dispayet
    My Bang & Olufsen....
    • BeoCenter 2 DAB/DVD mk.II
    • BeoVision 7-40 DVD mk.III
    • BeoLab Penta mk.III
    • BeoLab 4000 icepower
    • BeoLab 4000
    • BeoLab 3500
    • Beo 5
    • Beo 4 mk.I & mk.III
    • Beocom 6000
    • A8 Earphones
  • 11-21-2009 6:19 AM In reply to
    Quite correct - it is the software in the Penta. Mine are the same. No update available that I am aware of.
  • 11-21-2009 6:23 AM In reply to
    • PH
    • Not Ranked
    • Posts 16
    Hi and thanks for reply. I think we have to live with it Ick!
  • 11-22-2009 4:27 AM In reply to
    I have a similar issue with my mk1's the displays only work on cd but even then it displays the volume as '00'
    Any ideas??
