        1st March February 2012
	    Latest post 11-12-2009 8:41 AM by Peter Pan . 1 replies.
								    |  11-11-2009 7:12 AM |  |
									                 Peter PanJoined on 04-16-2007DanmarkPosts 741 |
										    Beo4 Mk III. Hvad dækker det over:
 Jeg syntes det kunne være spændende at få svar på hvorfor en Beo4 Mk III kan have forskellige EE nr. og hvad dækker det over. Software versionen ser jo ud til at være den samme på dem alle.
 Er det SW versionen der Feks. bestemmer hvor mange forskellige kommando muligheder man har at lægge i LIST.
 Og hvad mere er bestemt af SW'en. Hvor mange SW nr. findes der til Mk III, og hvordan lægges softwaren ind.
 _______________ Vidste du det? For at afgøre, hvilken version af Beo4 du har, prøv at trykke GO og MENU på samme tid,
 og derefter LIST for at 'rulle' gennem information. Det vil vise dig,  at i en ældre SAT-version
 kan stå, EE: 3.2 / SW3. I en nyere DTV-version kan stå, EE: 6.1 / SW 5.00.
										    Re: Beo4 Mk III spørgsmål.
BeoChamp skriver:      Peter min ven:  BeoChamp tryllet endnu en gang:
| Survey of Beo4 S/W versions |
EE 1.0:(Implemented week 32.94)
EE 1.2:(Implemented week 34.94)
"TRACKNG" removed from the list from the factory |
Possibility of lamp + 1# because of LC2 |
EE 1.1: (Implemented week 01.95)
New "SETUP" in light list (Þ GOTO) |
"PHONE" changed to "SP.DEMO" |
EE 1.61:(Implemented week 43.95)
Special EEprom together with S/W 1.1. for Avant |
"CAMCORD" and "DOORCAM" has been implemented |
"P-IN-P" moved further up the list |
"TURN" added in the V.TAPE list |
"LOUDNSS" with step up / step down added |
"SELECT", "TRACK" and "SUBCODE" removed from the factory |
"A.SETUP" and "V.SETUP" added |
/AV/+/GO/ from standby added |
EE 2.0:(Implemented week 29.95)
"P-IN-P" is moved further up in the list |
"CAMCORD", and "DOORCAM" added  |
"TURN" is added in the V.TAPE list |
Under "A.SETUP" the following functions have been included: |
-"SOUND" -"S.STORE"
 -"BASS"
 -"TREBLE"
 -"LOUDNSS"
Under "V.SETUP" the above and the following functions have been included: |
-"PICTURE" -"TUNE" function
 -"STORE" function
 -"CLEAR" function
EE 2.3:(Implemented from week 30.96)
The order of appearance of "TRACK", "RANDOM", "EDIT", and "SELECT" has been changed |
The order of appearance of "REVEAL", "UPDATE", "INDEX", "MIX" and "SUBCODE" has been changed |
"INDEX" and "REVEAL" removed from the factory |
(Implemented from week 39.96)
New configuration principle |
Read-out of configuration and EE/SW version |
Continuous on /GO/ as Action button  |
Pause between Continue commands changed from 140 ms to 30 ms because of CDI |
"RANDOM", "EDIT" and "REPEAT" activated on /cursor/ and list is closed |
Choice of test pattern via keys |
EE 3.0:(Implemented from week 39.96)
Order of appearance of "TRACK", "RANDOM", "EDIT" and "SELECT" is changed |
Order of appearance of "REVEAL", "UPDATE", "INDEX", "MIX" and "SUBCODE" is changed |
V.SETUP removed from the factory |
New configuration principle is hidden. Can be selected as follows:-/STANDBY/ and /LIST/ simultaneously
 -/MENU/ and /GO/ simultaneously
 -Display indicates "EE3"
 -/1/, /6/, /2/ and /0/
New configuration principle is available |
"NONE" in video configuration |
Secondary sources removed:-"L-V.AUX"
 -"L-A.TP2"
 -"L-CD2"
 -"L-CDV"
 -"P-V.AUX"
"SPEAKER" and "CLOCK" removed from Basic |
"SPEAKER" removed from BS9000 |  S/W 1.0 with matching EEprom versions
Except:Can be used by all products operated with Beo4 (i.e. products where the operation is described with Beo4 in the User's Guide).
-AV5 (Action buttons for controlling cursor-operated software on BeoCenter AV5)-MX Beo4 (no tuning)
 -AV9000 Beo4 (not possible to clear program on TV, SAT)
 -Avant with "CAMCORD" operation
 -LC2 (not possible to operate one single lamp)
 -Audio products using "SOUND", "BASS", etc. instead of "A.SETUP"
 S/W 1.1 and EE 1.1:
 S/W 1.1 and EE 1.16:
As EE 1.1 but with "CAMCORD" operation on Avant S/W 2.0 with matching EEprom version:
Except:Can be used by all Beo4 products (i.e. products where the operation is described with Beo4 in the User's Guide).
 S/W 3.0 with matching EEprom version:
Can be used by all Beo4 products With EE 3.0 the configuration is hidden |  |
| EE software 3.4 |
| Opdateret betjenings software EE 3.4
 Betjeningssoftwaren er blevet opdateret på grund af introduktionene af BeoLink® PC Office på markedet.
 Softwaren vises på Beo4 ved at trykke /STAND-BY/ og /LIST/ samtidig, derefter /MENU/ og /GO/ samtidig for at se EEPROM version.
 Softwaren opdateres ved at udskifte PCB, best. nr.: 8001827.
 Den nye software blev introduceret i produktionen fra serienummer:
 Type 1624 serienummer 13742246
 Type 1625 serienummer 13742646
EE 3.4fra serienummer 13742246
Svarende til EE 3.0 og 3.2
PC tilføjet til listen for at få PC-lyd gennem BeoLink Activej |
Sekundær kilde tilføjet (blev taget ud i software 3.2):
L-V.AUX er tilføjet på grund af Set Top Boxes L-CDV er tilføjet på grund af DVD |  |
| EEPROM Software 4.2 |
| Nye sekundære kilder er blevet tilføjet til LIST, p.g.a. indførelsen af BeoLink PC II.
N.RADIO, L-N.RA, N.MUSIC og L-N.MUS føjet til sekundære kilder N.RADIO og L-N.RA ved at bruge PHONO-kommandoen og RADIO-stak N.MUSIC og L-N.MUS ved at bruge ATAPE2-kommando og CD-stak L-PHONO og P-V.TP2 fjernet fra sekundære kilder CMD_CONTINUE kan bruges på MENU, STOP og RECORD TRACK, RANDOM, EDIT, SELECT, REPEAT og A.SETUP ændret til default i BV1 STAND tilføjet som default i alle stakke i BC1 og BV1 konfiguration Sekundære kilder tilføjet i TEXT stak i BC1 og BV1 konfiguration.
Beo4 indholder to slags software:
|  |  |  |  Softwaren vises på Beo4 ved at trykke /STAND-BY/ og /LIST/ samtidigt, og så /MENU/ og /GO/ samtidigt for at se EEPROM version.
 Tryk /LIST/ for at se software version.
 Softwaren opdateres ved at udskifte PCBen med bestillingsnr.: 8001806.
 Den nye software er blevet indført i produktionen af typerne 1624 and 1625 fra serienr.: 14903590
| Software 4.4 og DVD knap |
| En ny DVD knap erstatter AV knappen på Beo4 betjeningspanelet. AV knappen er flyttet til LIST. I den opdaterede SW4.4 er det muligt at oprette en prioriteret liste. Det betyder, at det er hurtigere at finde de hyppigst anvendte LIST knapper, når man benytter LIST funktionen.
| Beo4 omfatter to slags software: |  | SW 4.4 |
|  |  | EE 4.0 |  Software kan vises på Beo4 ved at trykke /STAND-BY/ og /LIST/ samtidig, og derefter /MENU/ og /GO/ samtidig for at se EEPROM versionen.
 Tryk /LIST/ for at se S/W versionen.
 Softwaren opdateres ved at udskifte PCB, best.nr.: 8001806.
 Knapsættet (betjeningspanel) med DVD knap har best.nr.: 2776627 for type 1624
 2776628 for type 1625
 The Beo4 DVD remote control has part no.: 1162411
 1162511 for Italy
 Den nye software er indført i produktionen af typer 1624 og 1625 fra serienr. 14228550.
| SW 4.4 |
DVD knap Erstatter AV knappen, AV knappen er flyttet til LIST
MOVE funktionen er tilføjet til LISTVed tryk på GO flyttes funktionen til begyndelsen af LIST.
 Ved tryk på et tal flyttes funktionen der er vist i displayet til den valgte position i LIST.
 Så snart CONFIG? bruges bliver Beo4 reset til fabriksopsætningen.
P-V.AUX er tilføjet til LIST
P-PC er tilføjet til LIST
P-V.TP2 er tilføjet til LIST
Nye produkter i CONFIG list (AVANT-US, BV 1, BC 1)
Når en sekundær kilde vælges, slukkes displayet i 300 msek. for at give kunden tilbagemelding på handlingen (hvis nummer 1 i LIST, slukkes displayet i 300 msek. når man trykker på LIST knappen)
Når LIST knappen holdes nede, skifter retningen af LIST frekvensen ikke længere.
Udlæsning af serienr. i displayet.I service mode (STBY + LIST) + (MENU + GO) kan serienr. udlæses.
 Denne funktion ligger sidst i Service mode sekvensen, og hedder: SER.NO?.
 Ved tryk på GO udlæses de mest betydningsfulde tald (HI:8765) og ved tryk på LIST udlæses de mindst betydningsfulde tal (LO:4321).
 Serienr. forprogrammeres i fremtiden
| New SW EE6.0 |
| New functions and new CONFIG
 The CONFIG has been changed:
 VIDEO-1 "AVANT CHASSIS" , AVANT, BV 3 -32",
 VIDEO-2 Beocenter/Beovision 1 and MX
 VIDEO-3 US TV
 AUDIO-1 Basic audio
 AUDIO-2 BS 9000
 It is now possible to add RANDOM to A-TAPE (For BS 3200)
| Beo4 contains two kinds of software: |  |  |
|  |  |  |  The software is displayed on Beo4 by pressing /STAND-BY/ and /LIST/ simultaneously, then /MENU/ and /GO/ simultaneously to see EEPROM version.
 Press /LIST/ to see S/W version.
 The software is updated by replacing the PCB, part no.: 8001806.
 New SW from approx. December 2007
 Dette er eneste opdatering |
________________________________________________________
| Softwareopdatering til version 6.22 - DTV2 tilføjet |
Nye funktioner DTV2 tilføjet P-DTV2 tilføjet L-DTV2 tilføjet A-DTV2 tilføjet   REC LOCK fjernet REC UNLOCK fjernet   Løsning For at opdatere Beo4 fjernbetjeninger, der er ældre end serienummer 00379978 (fremstillet før 7. september 2007), skal du bestille PCB'en med EE-version 6.22, part-nr. 8001806. Nyt tastatur (med V.MEM, A.MEM og DTV) og en vejledning følger med.   For at opdatere Beo4 fjernbetjeninger, der er ældre end serienummer 00379978 (fremstillet efter 7. september 2007), skal du bestille PCB'en med EE-version 6.22, part-nr. 8003006.    Kompatibilitet Softwareversionen er 5.00.   Der findes 4 forskellige EE-versioner, hvor EE-versionen bestemmer, hvad der står på listen, når fjernbetjeningen forlader fabrikken.   EE-versioner:   Video1/Audio1: 6.19 Video2/Audio1: 6.20 Video3/Audio2: 6.21 Video4/Audio1: 6.22   Første serienummer og dato for indførelse
| Produkt | Serienummer | Dato for indførelse |
| Beo4 | 00379978 | 7. september 2007 |  |  |
						     Page 1 of 1 (2 items)  |
