I think i found the "medie center" that fulfil my demands for a medie center, i found the Popcorn Hour, But i can see that there is no PUC codes for that device :(
So the only soulution i can see is too buy a BEO 5, but the media center shall be placed in closed cabinet. So is it possible to use BEO 5 with a box without PUC where there not is line of sight between beo 5 and the medie center?
Thanks in advance!
