I purcased a AV9000 TV and control panel, the control panel was working except for the tape player. I was told the belt was probably the problem, so i decided to have a look and decided not to bother after seeing all the wiring once i took it apart. My problem now is since putting it back together the doors wont work, the cd eye goes staight up to the top when cd is selected. The radio works but is hard to get in tune seems to be doing a lot of hissing now, oh and the tape still doesnt work. I never took any wiring apart or diconnected anything i just took the doors of and took the casing apart,i wish i did not now though.
Is their anyone out there who has worked on these before and has any advise for me, or even is prepared to have a look at it for me as you have probably realised a specialist i am not. I have had a B&O's sevice engineer look at it which cost £85.00, but they did not not want to touch the system, but did say they could replace it for a overture which would need modifying to work with the TV at a cost of £650.00.
Hopefully there is someone who can help.
Thanks.
Steve
