1st March February 2012
Latest post 11-05-2009 4:11 AM by JC. 5 replies.
11-03-2009 11:39 AM
JC
- Joined on 04-16-2007
- Yorkshire / UK
- Posts 621
BV 7, X box and music, not too stupid a question I hope
Ok guys and gals. When playing Xbox is it possible to play a CD or radio via my 9000 at the same time?
The BV7 is MasterLinked to the 9000 and I am running front and rears as well as a sub from the TV.
It would just be nice to have a bit of music instead of POW, THWACK ect'.
Jonnie
jk1002
- Boston USA
- Posts 1,620
Re: BV 7, X box and music, not too stupid a question I hope
I was wondering the same thing while playing Wii on my BV8.
I think the answer is no. I had to change the option setup and did connect my BL3/BL2 straight to my BC2 for music. TV now runs through BV8 speaker only.
JC
- Yorkshire / UK
- Posts 621
Thanks for that, hope there is a way round it.
Jonnie
Quim43
- Joined on 11-15-2007
- Tarragona (Catalonia)
- Posts 1,030
Hi Jonnie
You just have to press AV and then Radio or CD, as you want. You will watch the game but you will hear the music of your 9000.
leogenghis
- Joined on 12-08-2008
- Posts 169
Hey Jonnie,
Quim is right. On the Beo4 hit LIST until it displays AV (if you don't have AV, program the Beo4 to add it to the list), followed by Radio or CD. Works like a charm on my system. When you want to go back to XBox audio, hit TV or whatever button you normally select again. The screen might black out for a second or two while it re-adjusts (at least it does on mine).
Leo
BV 10-40, BV 8-32, BL 9, BL 4, CX100, BS Ouverture, BS 2000, BG 4500, Passive, LC 1, A 9
JC
- Yorkshire / UK
- Posts 621
Brilliant! I will give it a try later.
Jonnie
Page 1 of 1 (6 items)
