Latest post 10-25-2009 8:22 AM by tompa. 1 replies.
Page 1 of 1 (2 items)
  • 10-24-2009 11:25 AM
    • mjmedlo
    • Top 150 Contributor
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    ML Wireless Question
    I have a wireless kit connected to a BV9 set to transmit.
    This allows me to get music to my BS9k in the bedroom (wireless on receive).
    Is there any way to play the CDs on through the BV9 setup?  I assume not since
    one is transmit and one is receive?  Is there any way to transmit from the bs9k to the
    other rooms without an ML cable?
    THanks
    MJM
    I'm ready for something new that I actually want to buy!
  • 10-25-2009 8:22 AM In reply to
    • tompa
    • Top 500 Contributor
    • Joined on 06-30-2007
    • Sweden
    • Posts 94
    Re: ML Wireless Question
    It's possible but you have to change wireless to transmit in BS9000 room and change option on bs9000 to audiomaster and receive
    on wireless in BV9 room, but i guess you have a another audiomaster in the same room as bv9? if so it,s not possible because
    you can only have one audiomaster in the setup, maybe one solutions is to use a non b&o audio/video wireless transmitter
    to send "audio out" from bs9000 to the audiomaster in bv9 room to aux input but in that setup you have to start ex cd manual
    on bs9000 and you cannot select track/radio outside the bs9000 room
    Regards
    Tompa
