when will it be launch?
what price?
thanks
never explain never complain
rumour from here: before December
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
The pricetag= €16000 Euros including floorstand and Beolab 7-6 (BL7-6 is the same as the BL 7-2, but wider)
Release in late dec.
BL8000 MkII Black
Now that BV10 is out, we have someting more to speculate :-)
If it comes in 55 it will look stunning!
I love my 7-40 but for 55" you really need a good distance to the TV set, otherwise it looks like too much... that counts for the 104 as well :-)
are you sure of the price (16000 euros) with blue ray
Yes, according to B&O on the dealer meet in Struer.
I think the prize of 16grands are right.
The BV4-50 cost over 19grands with BL10. It is on the same level of euros.
The BL7-6 will be about 166 cm (5.44 ft) length In vertical possition is taller than my mother
Jq. BS4 BL3 A8 Form2
