A couple of questions please, if someone can help me?
I've just bought a Beogram 3000 type 5228. The cartridge needs a new stylus (Axel can do this re-tip for not much money) usual linkages need cleaning but the motor runs and the belt seems to have some life in it yet.
My questions are as follows - The platter is original, but I'm sure the 3000 decks I've seen had a lead ring around the perifery of the underside of the top platter disc to add mass. This one doesn't and never had, although the rubbery rings are there to support the record.
The second question concerns the trim on the "lift" button. Does this trim disc still exist as a spare part, or does someone here have a spare they could sell me? The switch works fine, it's just the stick-on trim with "Lift" silk-screened on that I need.
Hope someone can help me with the second enquiry and either confirm or deny my failing memory of the platter mass-loading...
Thanks, Dave
