Latest post 12-27-2009 1:51 PM by Beowulf. 3 replies.
Page 1 of 1 (4 items)
  • 12-27-2009 10:37 AM
    • Beowulf
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Derbyshire
    • Posts 143
    MX7000
    Hi, Trying to adjust the picture on an MX7000 (Christmas present to Girlfriend! from Lifestyle AV) Unfortunately when I press list on the Beo4 there are no settings for colour, contrast, sound, bass, treble etc. Gone through the list of things I can add without any luck Unsure Thanks in anticipation of a solution.
    Kind regards
    Dave
    Beowulf
  • 12-27-2009 10:56 AM In reply to
    Re: MX7000
    There's no V.setup or A.setup under list and you can't add those either?
  • 12-27-2009 12:14 PM In reply to
    • Neil
    • Not Ranked
    • Joined on 01-13-2009
    • UK
    • Posts 34
    • Gold Member
    Re: MX7000
    Dave
    Selecting "menu" on the Beo4 remote should give you access to the user adjustments.
    Regards,
    Neil.
  • 12-27-2009 1:51 PM In reply to
    • Beowulf
    • Derbyshire
    • Posts 143
    Re: MX7000
    Thanks Neil and Beocool,
    Sorted by going into the sub menu under picture and a little patience.
    Limited scope within the main menu which only lists scart, s-vhs, power link and timer.
    Now off to the best pub in Somerset for a pint of farm cider, may have problems focusing on the picture later! Is there anyway I can make an adjustment for this???Unsure
    All the best for the New Year!
    DaveBeerDrinks
    Beowulf
