Latest post 10-15-2009 12:37 PM by Alain-Olivier. 1 replies.
Page 1 of 1 (2 items)
  • 10-15-2009 12:03 PM
    Mid-range BeoLab Penta
    Bonjour,
    I need to replace the mid-range drivers on my BeoLab Pentas type 6633. The one installed by B&O are Nokia ones. I have been told that they are still available, but I have read on the forum that they are really not of the best quality, very standard indeed.
    Has anyone had any luck with replacing them for other brands, could they actually have better caracteritics?. Last question, foam (that will rot eventually) or rubber. Will there be a real difference that can be heard?
    Regards
    Alain-Olivier
    Filed under:
  • 10-15-2009 12:37 PM In reply to
    Re: Mid-range BeoLab Penta
    T
