My Serene phone originally came from B&O Dubai and so the dock had a two pin plug........ easily accomodated in the UK with a two pin adapter.
However, when I decided to buy a travel adapter/charger in the UK, it came with a UK 3 pin plug. No doubt this has got something to do with UK electrical legislation, but surely a travel adapter with 3 pins that can only be used in the UK is a bit crazy?
Also, increasingly instructions now carry warnings not to cut wires to change plugs but to purchase only complete power cords.
Graham
I used to be indecisive, now I'm not so sure. [W C Fields]
