No problem.
I'm using a 5 Metre DIN - RCA cable, cost me £50 a pair
from B&O. My local B&O store have popped over to examine this and it
appears to be that the Duet, although has great sound output, the volume levels
from the squeezebox are not as gradual as Bang & Olufsen Audios systems.
For example Bang & Olufsen Audio system will go: 1,2,3,4,5,6,7,8 and so on,
where as it seemed that the squeezebox is more like 4,8,12,16. So volume 0 is
0, but Volume 1 is 4, do you see? This is my problem, volume 1 on some songs is
actually quite high and is too high to listem as background sound.
