Hi ,
Can you tell me what audio connections the Runco provides?  Is it an all-in-one screen, or is there an external processor, etc.  What you're looking for is a variable, line-level output.  And even then you'll need an external relay to activate the BeoLab 2.
OK, so I'm off work today, with time to kill while the laundry runs....  A quick look at the Runco website tells me that these are all strictly video monitors, with no provision for audio at all.  Be sure to talk things over with your dealer before you pull the trigger on this deal.  If I've understood your post correctly you have either a BeoVision 5, or a BeoVision 4 with either a BeoSystem 1 or 3.  In the case of the BeoVision 5, the Audio processor is in the TV and will leave the room with it.  in the case of the BeoVision 4, the external processor ought to be able to handle the Runco Screen, and obviously the speakers.
									    We kid because we love.
Bang & Olufsen Tysons Galleria
McLean, VA  USA
