The recommended setup for the Avant DVD is:
1) Video: connect the S-video and/or the CVBS-output on the BM1 to the scart on the Avant
2) Audio: connect the mini jack to the audio output on the BM1
3) Connect the IR eye to IR socket (and power and ML). Remember to have the keyboard and mouse connected to the BM1 through the setup procedure.
On your Avant: Select <setup> or <options> and <connections> to select the correct AV-input used. You shoud select V.AUX (not PC, as it is not supported). You shall now use V.AUX in the display of the Beo4.
Setup of the BM1:
1) Select BM1 by pressing V.AUX on the Beo4.
2) Power up the BM1. Wait till the main menu of the BM1 is shown on the screen.
3) Go to <configuration> by pressing <R> on the keyboard followed by <9>
4) Make sure, under System Settings, that the command is V.AUX and that the correct option is given (VM option 1 or 2).
From now on you can use the Beo4 for most of the setup, and not the keyboard, if you wish. Exit System Settings by pressing <ESC> on the keyboard or <EXIT> on the Beo4.
Roger
